@aag110 , ahmed , You can try a soft reset, press and hold the power button, from the options choose power off and then tap OK, wait a few seconds, now hold down the power button again to turn the phone back on(may have to try a couple times). If this is not working proceed to below(factory reset).
A lot of forums state to hard/ factory reset your device to fix this type of issue. In doing so you will loose all data that is not backed up.
Factory Reset:
-If the display is off hold down the power key to switch it back on.
-Then go to settings and then to backup and reset.
-Now, tap factory data reset and reset phone.
-Next, choose erase everything, ((you will clear all your data)).
-Select OK, to confirm reset operation.
See link below for more possible solutions. Good luck.
http://www.hardreset.info/devices/sony/s...
4 件のコメント
I have the same problm with my sony xperia xa1 already reset it...but keep on doing the same thing...
gershwald franklin さんによる
My phone is turning on and off when it's charging or when it comes right off the charger does it have to do with the charger
Gina Davis さんによる
I have the same issue. I think Sony when it come to the mobile technology, they are very behind. It is only name that they have, as they spend a lot of money on advertisement. Otherwise, once it is known issue, they should have stepped up on the plate and come up with solutions. Never will I recommend anybody to purchase Sony products.
nyala2004 さんによる
I have sony xperia z5 and always keep restarting. Battery problem, overheated. Maybe it because the cpu to hot. That make battery like $@$*
Nik Nik さんによる
