Ultra Power Saving Mode & Touchwiz Home Screen Leaves Me In Limbo
I turned on Ultra Power Saving Mode. Then I hit my home button, and it asked me what home screen I wanted to use as the default. I accidentally hit "Touchwiz Home", and now I'm stuck.
My options under settings now are: Wi-Fi, Bluetooth, Airplane Mode, Mobile Networks, Location, Sounds & Vibration, Brightness.
When I go to my Apps, the apps available are: AT&T Protect Plus, Calculator, Chrome, Contacts, MaaS360, Messages, Mobile Hotspot, Phone, Whatsapp.
On my home screen, I can hit "Edit", which lets me add apps to the main screen, or "Help". When I hit help, I get "Unfourtunately, TouchWiz easy home has stopped."
There is no where for me to get back to my normal home screen and normal apps. Or to turn of Ultra Power Saving Mode. Help. I really don't want to factory reset this phone.
I don't know what level of Android I'm using. But I'd guess it's the Verizon download from about 3-6 months ago.
Thx.
この質問は役に立ちましたか?
17 件のコメント
BTW. I've rebooted it several times. I booted it into Safe Mode, and it still doesn't give me options to get out of UPSM. I also connected it to a PC using a USB cord, and it's not even recognized as being connected.
Antonio Mazzarelli さんによる
Have you gone into full settings? I mean, did you swipe down, swipe down again then click the gear in the corner?
George A. さんによる
When I swipe down, I see only the time and a settings gear. Swiping down again does nothing. Hitting that Settings gear gives me only the settings I listed.
Same in safe mode? Do you mind if your phone is reset? You should be able to access photos here: https.photos.google.com
And contacts here:
https.contacts.google.com
A system reset is good for a phone once in a while. It should solve the problem.
George A. さんによる
I have text messages on the phone I don't want to lose. Resetting it will lose those, right?
12件以上のコメントを表示
