メインコンテンツにスキップ
Toshiba Satellite C75D Notebook. Part of Toshiba's "budget conscious" C-series of laptops, released in 2013.
15回答 すべてを表示
Can the CPU be upgraded in in my Toshiba Satellite C75D?
I would love to upgrade the processor of my C75D?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
There may be a something you could do to make your PC faster besides a CPU upgrade. What exactly do you need from your laptop?
さんによる
コメントを追加
3件の回答
選択されたソリューション
The processor can not be changed out. If you're looking for more speed, I would suggest installing more RAM and a solid state drive. As far as technical limitations are concerned, the motherboard can handle up to 16GB of 1333Mhz DDR3 SODIMM, running at 1.35v. The brand doesn't really matter, as they all do the same thing.
Any 2.5" solid state drive will fit, and the prices have come down considerably. There are a lot of 480GB drives available around $130 +/- on Amazon. You'd notice a huge difference with just the solid state drive.
このアンサーは役に立ちましたか?
スコア 3
コメント:
DDR3 running at 1.35v is DDR3L. The L stands for low voltage. Standard DDR3 is 1.5v.
さんによる
However, it isn't always listed as DDR3L. Crucial and Kingston both have RAM offered at 1.35v without the "L" indicator. As I'm sure many other companies do, as well.
さんによる
I am aware of that. Normally when they do that, the ram is cross-compatible.
さんによる
コメントを追加
最も参考になった回答
Bobby Hayes , From what I have read on the forums, your processor is soldered to the board and is considered not up gradable. Good luck.
このアンサーは役に立ちましたか?
スコア 3
コメント:
DARN! Thanks for the info!
さんによる
darn is the light name for what I consider to that, why would they do this when other processors are easy removed I just found out this in 2019 im guessing the info about my processor is that it is an 4 core which helps in the top few over the 2 core so I just upgraded my ram and hd almost time for another step up …..
さんによる
Hello, I own a Toshiba laptop model C855D-S5351 socket FP2 (827) processor AMD A6 - 4400M Can I upgrade the processor to a newer version and what is the version number Thank you very much
さんによる
コメントを追加
I have a A505 and the cpu is a socket processor it is not soldered.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bobby Hayes さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 22
過去 30 日: 68
今までの合計 5,630
