メインコンテンツにスキップ
Appleの iPhone 5sは2013年9月10日に発表されました。このデバイスの修理は全モデルの修理と類似しています。そしてスクリュードライバー、こじ開けツールが必要です。GSM か CDMA、16か32、64GBがあり、色はシルバー、ゴールド、スプレーグレイが選べます。
3870の回答 すべて表示
iPhone 5s crashing after battery change
Hi there
I was in the believe that a batery change was the only problem with the iphone 5s when it turned hot and said it has to cool down before i could use it again. I changed the battery just to find out the phone crashes all the time, the phone boots up some times when pluged into charger, and some times i have to hold power and home button to get it boot up. Do anyone have a clue to what issues i´m facing?
Regards from Denmark
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
1回答
選択されたソリューション
Hello Carsten. If you are confident that you have used a known-good quality replacement battery, then I would ask where is the excess heat on your device?
There are 4 thermistors on the logic board (forehead, RCAM, Baseband & CPU) so if anyone of those areas detects excess heat, it will send you that error message. So wherever the heat is, that is probably where the problem is. It is unlikely that the thermistors themselves have failed although it is not impossible. More than likely, there is high current going through one of those areas due to a partial or full short caused by a bad component or module.
To eliminate any issues with the camera or front screen (forehead), remove the logic board and connect only the charge port and battery and see if iTunes sees the device. Then progressively add the screen (no fcam), home button, fcam, rcam etc until the message shows up. If it is in the baseband or or CPU area, the message will appear quickly.
Your problem will either be modular (i.e. camera) or logic board.
この回答は役に立ちましたか?
スコア 3
コメント:
Hi Minho
And thanks for your answer. I have noticed that the heat is coming from the right side on the midle of the phone.
による
On the front of the device or back? The front mid-section corresponds to the CPU but on the back it is the PMIC. Once it gets hot enough it's hard to tell the difference but with the logic board removed, you should be able to tell.
による
コメントを追加
回答を追加する
Carsten さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 117
