External Hard drive repair
anyone know if you can fix an external hard drive? or take the information off? xbox shows red ring when its hooked up and doesnt when its unplugged.
You can actually just fix that with iFixit's RROD fix kit, here's the guide for using it.
このアンサーは役に立ちましたか?
I suggest you check on the link provided since I have a feeling that you are thinking that you are not necessarily dealing with an overheating issue. It might help you with the trouble shooting. http://www.wikixbox360.com/page/Xbox+360...|+Troubleshooting+FAQ
and this site has tons of info on the Xbox 360 http://forums.afterdawn.com/ so give it a try and good Luck :)
このアンサーは役に立ちましたか?
I had the red ring once but mine was an easy fix I just had to check my hook ups an then it started workin fine there is ways I've seen on youtube that people fix them but I've not tried but I hope u can figure it out
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,064
I have 3 hard drives for my xbox 360 1 is a 60gb 1 is a 20gb an the other is a 500gb the 60 an the 20 work fine but the 500 just stoped all a sudden it worked untill I turned my system off then back on the other to still work but the 500 don't if u find any info on this please let me know
Timothy Spencer さんによる
