Where I can buy this this connector? and what does it call?
https://drive.google.com/open?id=0ByS5BI...
I looking for this part to repair my Alienware 15.
I have attached a link to the service manual for the Alienware 15 model. On page 28, the cable you circled in black in your photo appears to be labeled the "Keyboard Backlight Cable". I can't find a part number for just the cable, so you may have to replace the entire keyboard to replace that one cable. If you do a search in your browser for "Alienware 15 replacement keyboard", you will find several options to choose from. Just make sure it is the correct part number before ordering anything.
このアンサーは役に立ちましたか?
Hi @icefreak
I do hope that you're right and it is the cable. I saw this question before and wondered if the OP meant the actual connector socket on the pcb rather than the flex cable plug connector. It is a type of ZIF connector isn't it? Good luck fixing that if it is the socket on the board and has been pulled off!
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 120
