How to Reinstall EMI Shield after cleaning
iphone 5, I have reason to believe that the logic board has water damaged parts under the EMI shield.
how would I reinstall the shield after removing and cleaning?
Clean up or flatten out all the shield solder joints with a soldering iron and wick if you need it. Slip the shield back on and use an iron to solder the points again. You don't need to do a perfect job on every single joint. It helps if you try an avoid prying/bending the shield during removal.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 94
1件のコメント
Read the answer below.
icaremore さんによる
