メインコンテンツにスキップ
PlayStation 3 (PS3)はソニーコンピューターエンターテイメントによって製造された3世代目の家庭用据え置き機で、PlayStation 2の次世代機となります。これらは2006年11月11日に発売されました。
783回答 すべてを表示
MY PS3 Game Control Ports Don't Work
Is there anyway to repair the usb ports on the front of the fat ps3, I've tried multiple controls on this one PS3 and nothing works still. It looks like these ports or glued on the board, so i'm just asking how can I get around this if in all repairable.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
最も参考になった回答
The USB ports are soldered to the board and unless there is physical damage to the USB ports I would not bother replacing them. Sony was nice enough to use proprietary ports that are on their motherboard so purchasing replacement ones from Digi-Key is not an option. Instead, obtaining another motherboard from a broken PS3 would be the best option if you do want to replace the ports. If you have never soldered before and the USB ports are your only problem, then I recommend that you strive to find someone who is experienced with that. Replacing the motherboard all together is a bad idea as well since the Blu-Ray drive and motherboard are married together and must be paired, and spoofing the drive to match the motherboard is not something I have seen done on a PS3 yet.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Hi there
thanks for the response, i'm happy with all you said, so before reading this, I was looking to buy a replacement online and I found one on ebay. However I tried a little something before even buying one from ebay. I took the port out, fluxed it very well and I heated up all the chips on both sides of the usb ports and wow it's working again, so i'll see and hope this hold up if it does then maybe that is also an option.
thanks again for all your input
さんによる
コメントを追加
You may need to send this in for repair. You should try [URL|http://www.videogame911.com]. They do really good repairs and beat manufacturers pricing.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi, my ps3 usb ports are not working and there is no faulty with cable can you help me please?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my usb port is broke on my ps3 the model is 160 slim cech-2501a the white part came out what can I do
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
コメントを追加
回答を追加する
jasonConnors さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 23
今までの合計 10,636
