メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1623回答 すべてを表示
2012 MacBook Pro stopped working
Ok I've got this 2012 MacBook Pro that somewhat turns on, fan runs heavy, battery seems to be charging (charger leds and battery leds work), front led lights up but laptop doesn't chimes and screen keeps black.
Screen has no cracks or scratches, laptop wasn't water damaged or impact damaged.
I cleaned everything with isopropyl anyway: all contacts, whole logic board (both sides), replaced thermal paste, etc.
Also tried 3 different sets of 2x2gb ram and 2 different HDDs too.
Disconnected battery and tried turning it on with charger only (60w charger). Also considered replacing battery but if it doesn't work with charger only (battery disconnected) might rule it out? :-)
Oh and it doesn't boot from USB, doesn't boot on safe mode or verbose mode. But took a DVD in and seemed to run it but now won't eject it (it was a movie DVD instead of OS X DVD unfortunately)
To be honest I did it all very quickly and plant to have another look tomorrow after work but has anyone got any ideas you might suggest me to try? I feel this laptop is salvageable but I'm feeling a bit lost here :P
Any suggestion would be very appreciated :-)
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント:
Connect a monitor to the computer to rule-out dead LCD. Sounds like possible GPU failure.
さんによる
Thunderbolt digital video output
Native Mini DisplayPort output
DVI output using Mini DisplayPort to DVI Adapter (sold separately)
VGA output using Mini DisplayPort to VGA Adapter (sold separately)
Dual-link DVI output using Mini DisplayPort to Dual-Link DVI Adapter (sold separately)
HDMI audio and video output using third-party Mini DisplayPort to HDMI Adapter (sold separately)
さんによる
I have the exact same issue and no solution
さんによる
コメントを追加
3件の回答
In my experience on newer Macs, they still run when the battery is gone and plugged into power, so I don't think it is your battery necessarily. The lack of a chime is concerning to me. It could be that the volume is down, but it could also mean that it is failing the POST.
Have you tried an SMC reset and an NVRAM reset? Technically disconnecting the battery and power will reset the NVRAM, but worth a shot right?
To reset SMC hold down Shift + Control + Option and hit the power button, while plugged in. You should see the charger LED change from Red to Green and back or Green to Red and back, depending on if it is fully charged or not.
If that doesn't work, hit the power button and immediately hold down CMD + Option + P + R and wait until you hear the chime. If you don't hear it after a while, it didn't work.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
PRAM/SMC reset didn't work. Didn't expect it to, but tried anyway.
Can't test on external monitor, would require a Thunderbolt Display and I don't have any around...
Will double check the logic board to see if I find anything obvious but I'm almost ruling it out as 'unsalvageable'... :(
さんによる
Would love to but I'm in NZ, you can find sheep in every corner and that's about it lol
Will try to find a cheap(ish) replacement or just sell as-is for parts...
さんによる
コメントを追加
I feel ya, it seems since Apple products from 2011 are now considered vintage we Apple mid 13 inch owners are next. I have many more macbooks, but this is special to me, and im sitll waiting for response from some on here for he instant white screen and loud fan issue. and strange other strange beaviors. I should've suck first party accessories this whole time.
Hoepfully some can help me with the white screen issue I am expeirncing. defintely pre chime pre kernal
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I'm buying isopropyl alcohol tomorrow leave it in a tray then I'll let the logic board sit there for some minutes. Perhaps even use a soft brush.
After that let it dry out for some minutes, re-install and hope for the best.
Only other solution I'm contemplating is to buy a used/refurbished logic board but again: I'm in NZ and it'll be hard to find and probably too expensive...
さんによる
I'm gettig off work i a few hours Carlos, i work at home for Apple chat adivosr. I have never ran into this situation in all my years working on macs. and even diong my special System Management Controller resets wouldnt work
White screen loud fans...
I hear cusomers compalin about loud fans on MacBook airs never on pros.
And i have naver had someone chat wthme abouut a white screen no post beep.
now granted,
I'm still using the faulty magsafe, which is kinda dumb, but i knwo its juscing he device. ok gotta back 3 chats at time
さんによる
Mark, sorry I missed this question when it first came up. White screen issues are usually a problem with the hard drive. Disconnect the internal drive and try booting from an external USB source with a current OS X installed on it. Then we can address your probable hard drive/IR cable issue. This also needs to be posted as a separate question as it is really not related to the problem the original poster was asking about.
さんによる
コメントを追加
Well I had to replace the logic board to make it work and that did the trick.
Still don't know if it could be fixed instead but that was the only thing I could think of after everything I tried - and I did tried a lot of things before spending in another logic board…
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carlos Ferrari さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 874
