How to replace my glass screen
My glass screen is broke and i ordered a replacement for it .i need to knw how to replace the glass screen
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Are you replacing the entire display assembly or just the glass . If your doing a complete assembly this may help
このアンサーは役に立ちましたか?
Just the glass
I just did the repair. Its best to order the digi and lcd assembly together. Pretty standard ZTE repair. Just beware the battery. Glued in pretty hard and there are cables underneath that can be damaged.
このアンサーは役に立ちましたか?
I am just beyond aggravated.....
I have found numerous websites/companies that sell the replacement screens for my ZTE Grand X Max 2, aka ZTE Z988. All of my touch sensors work fine, it's just the screen that's cracked.
But what good does it do to order a replacement screen if no one has any instructions on how to replace it? Am I just missing something somewhere? If anybody has any answers or suggestions please get back to me I would greatly appreciate it thank you.
I took apart an AT&T K88 (SRQ-K88). The digitizer is glued to the screen, so that in removing the glass I also cut the top layer off the digitizer. This replacement glass I ordered from ebay is now worthless. Do not order the glass only option.
I'm having the exact same problem I went to get up from sitting down on my porch next minute when I go to look at my phone it's like some ink has spilled all through it. And I don't know what to do. I would like to see if I can fix it on my own first. And if not then pay to have it fixed.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 5,500
