メインコンテンツにスキップ
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
35回答 すべてを表示
Motherboard powers off after 10 seconds of boot.
After I shutdown my laptop, I turn it on a while later and it powers on but then goes off after 10 seconds and doesn't show anything on the screen. No sounds or anything only the fan spins. The lights work perfectly and the motherboard receives power. So why, after all my good deeds, why is this happening to me. Please help me someone so that I may work on my unreal engine again.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Im not sure if this helps, I know computers will shut off if overheated. If I were you I would open the laptop up using a guide. Check the condition of the thermal paste on the CPU and replace it. Also be sure to blow out some of that dust once you're in it.
Hope it helps, Good luck!
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
I already did that bruh any other info I would really appreciate it.
さんによる
I tried everything I know possible please help.
さんによる
Do the lights stay on or does EVERYTHING power off after 10 seconds?
さんによる
Everything powers off please keep helping.
さんによる
When turning on, look at the lights do you show any blinking sequence at all?
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
j.bernard2002 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 102
