Changing the plastic that attaches to the blade
When you take out the cup that contains the blades you'll see a plastic circle with a nut in the center to hold it to the motor. That plastic broke & I have bought a replacement but can't get the old nut off the motor. Suggestions?!?!
8 件のコメント
Hi John, can you tell me where you bought that plastic disc...? Mine is broken but I can't seem to find one. Thank you.
Laura Kelly さんによる
amazon.com is where I got my replacements they have an range of attachments to the nutrabullet
Gwendolyn Cummings さんによる
I’m also trying wd40 and pliers as the plastics broke off. The screw is completely stuck. Can anyone help please?
Jowest さんによる
I tried all of these videos and the old disk won't budge. I hate to throw a perfectly fine nutribullet in the trash just because the disk is damaged. But I have no choice.
Leslie g. さんによる
Hey Leslie g
Try this that I did you can fix it
My old post
I’m also stripping the screw top at the base trying to get it off. A hole in the side of the shaft would give much better leverage in a system that self tightens than a naff old screw and a hole in the plastic base that doesn’t let a screwdriver through,
OK
Found a solution. Remove the base plate (4 screws), wiggle the plastic fan off the shaft of the screw head (now stripped because it is very difficult to get effective torque with that much surface area to screwdriver surface area plus really soft metal) and grip the ribbed shaft with pliers while turning the plastic base gear up top.
Really Nutribullet a loosening direction arrow (because it is opposite what is usual and difficult to deduce from mirror image videos) and a hole in the shaft to ease turning would make changing this so much easier and so much less landfill.
Tina woods さんによる
3件以上のコメントを表示
