Any way to turn on phone without power button?
I ripped the cable connecting the power button and volume buttons. What other way can I check that the phone turns on ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try: connecting the two Power cables that were attached to the button, if not, then try giving each of the power cables a bit of a shock == (Be careful not to short your phone, DO NOT LEAVE THE CURRENT ON FOR MORE THAN about 1 SECOND) ==
Edit 02/02/17
This was an idea because the power button may be jammed and this just sounded like a reasonable answer because when you connect the wires the system gets the signal to start up so try do this see what happens but try it on an old phone
このアンサーは役に立ちましたか?
@kurt_1411 help me lol
このアンサーは役に立ちましたか?
LOL uh look at a teardown xD
The wires that used to be attached to the power button, try connecting them as if you were pressing the power button
I need a picture of your whole phone pls
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 1,501
