Why my wifi won't activate?
My phone wifi won't activate and I allready firewire it with odin and a factory rest after that, is there anything I can do?
Are you using a custom firmware? If so that could possibly do it. Other than that if it isn't turning on and you've tried a factory reset and you've re-flashed the phone then it could possibly be a chip in the phone that either needs re-soldered or replaced. Might be best to have a repair shop look at it. Same goes with the bluetooth. Wifi and bluetooth commonly share a chip inside the phone in Samsung phones.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 306
Did you falsh it to stock rom or any custom rom? In some custom roms the Wifi is not working, usually is writen under "doesn't work"
Claes さんによる
