メインコンテンツにスキップ
A Wi-Fi and NFC capable CMOS camera first released in March 2013. Identified by model number EV-NX300ZBQUUS.
32回答 すべてを表示
What do I have many vertical colored stripes on my screen
My screen is full of colored vertical stripes. I have changed SD cards, cleaned battery and compartment, nothing has worked. What is wrong and what should I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Jayeff.
Thanks so much for taking the time to help me with is. I will now start testing as you suggest. Your instructions are very clear.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi,
Try taking a picture, (I realize that you cannot "see" what you are taking) and then download it onto a PC to see if it is alright?
If the picture is OK then you have a problem with the LCD screen in the camera.
Here is a link to the Ifixit guide on how to replace the LCD screen in your camera.
Samsung NX300 and NX300M Back Panel Assembly Replacement
Here is a link to suppliers of the part. It is not a recommendation to use any of them it is just shown to give to an idea of the price and what it looks like. Just search online for Samsung NX300 LCD screen for more suppliers which may suit you better.
http://www.ebay.com/sch/i.html?_from=R40....
If the picture is not OK, does the menu screen work OK?
If it does then you most probably have a problem with the CMOS sensor in the camera.
Here is a link to the Ifixit guide on how to replace the CMOS sensor in your camera.
Samsung NX300 CMOS Sensor Assembly Replacement.
Unfortunately I have been unable to find a replacement part, perhaps you may have better luck
If it doesn't then you most probably have a motherboard problem. Here is a link to the Ifixit guide on how to replace the motherboard.
Samsung NX300 Motherboard Replacement
Again I cannot find a replacement motherboard either.
hopefully this is of some help.
Samsung NX300 Motherboardの画像
ガイド
難易度:
中レベル
10 - 15 minutes
Samsung NX300 CMOS Sensor Assemblyの画像
ガイド
難易度:
中レベル
15 - 25 minutes
Samsung NX300 and NX300M Back Panel Assemblyの画像
ガイド
難易度:
簡単
5 - 10 minutes
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
ray さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 19
今までの合計 1,243
