メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Back camera not working. (Replacement not works also)
So I bought a used iPhone 5 with back camera not working. I thought I will replace the camera and sell it for the profit. The problem is, that I replaced the camera, and it still doesn't work. I thought maybe the replacement was broken too, so I found one more camera, replaced it again and IT STILL DID NOT WORKED. Decided to use it for a couple of days. After 2 hours it started to work. By then I thought everything is going to be OK, but after a couple days it is not working again.. Been using it with defective camera for 3 days now. Flash is not working too. In the camera app it displays yellow triangle in the upper left corner, which says "The iPhone needs to cool down to use the flash" (something like that). What could the problem be???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
I thing that the problem is on the motherboard. You will have defective control IC on your motherboard probably. Is your front camera function?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
front camera works. Only don't work compass and proximity sensor. I tried swapping front cameras for priximity sensor to work. That did not help either
さんによる
Interment issues usually points to a bad switching component on the board like he said. Camera ic is one of the most common failures.
さんによる
So the solution would be to replace the motherboard ?
さんによる
コメントを追加
Unless you have experience in rework or have replaced ic before then yes you would need a new motherboard
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
tomas.ukrinas1997 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 66
