メインコンテンツにスキップ
4輪駆動車やカーゴ付き乗用車の修理マニュアル
11706回答 すべてを表示
I have a 1998 camaro I am hearing a loud knocking sound.
It's knocking like it has no oil in it. I change the oil 2mos ago. I have not started it anymore. I need to get it fix l. What could it be?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hello,
Congrats owning a nice car such as that. I'm a truck/van guy so I can only speculate what's happening.
If your oil is not low, car not over heating, or sluggish to boost off (manual or auto) nine times out of ten with Cameros it's a loose converter bolt, flexplate issue or cracked flywheel.
You didn't mention if the knock can be heard only from inside, with hood open or only while driving. If it were a piston knocking under the hood you'd hear it knocking a mile away.
Shaun
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
When my hood is close are open I can hear it. I had just got it out the shop I had a new radiator put it in. And I got my oil changed 2mos ago. They it puts up I heard it when it putted in my driveway.
さんによる
When I here that I stop driving it.
さんによる
The oil was low.
さんによる
コメントを追加
回答を追加する
a.lathan44 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 39
