Can i use the 2nd gen ipod touch screen to fix the ipod touch 3rd gen
Can i use the 2nd gen ipod touch screen to fix the ipod touch 3rd gen 8gb just the screen is cracked......
この質問は役に立ちましたか?
この質問は役に立ちましたか?
When Apple released the 3rd Gen iPod Touch, they didn't update the 2nd Gen 8GB with a newer processor, or with Voice Commands, it was maintained as a 2nd Generation iPod Touch while being advertised as a 3rd Gen Device even though no changes were made. However, the 32GB was updated, and a 64GB iPod Touch was introduced.
Basically any iPod Touch that is 8GB in size that is in the 2nd Gen form factor (no cameras, tapered edges) is compatible only with 2nd Gen parts.
If you purchase a 3rd Gen part for your 8GB iPod Touch, it will NOT work. The connectors are that of the 2nd Gen and a 3rd Gen part will NOT fit.
このアンサーは役に立ちましたか?
+ great answer
Can i use a 2nd gen screen on a 64gb iPod touch 3rd gen?
このアンサーは役に立ちましたか?
No, only the 8GB is the same.
How i know wich gen is my ipod touch, between 2gn and 3gn
このアンサーは役に立ちましたか?
So you check the number at the back, it might say A1288 or A1318, (A1288 is Ipod 2nd gen) and (A1318 is Ipod 3rd gen).
Can I use iPod touch 3rd gen 8GB Glass panel on iPod touch 2nd gen 8GB?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 12,569
3 件のコメント
what about the 32gb version?
Adrian G さんによる
I actually ordered a 2nd gen lcd for my 3rd gen 8GB ipod touch. I will try it when I get all the parts and I will get back to you guys. Let's hope it works.
Philippe Dupuis さんによる
@Philippe Dupuis So does it work?
Shawn Cadelis さんによる
