メインコンテンツにスキップ
Apple Watch Series 2は2016年9月7日に発表され、同年9月16日に発売されました。
132回答 すべてを表示
Where is the button flex assembly connecting to the rest of the watch?
I'm a Product Designer and currently I'm working on a project that includes embedding an Apple watch. Because of this I'm researching about the components and structure of the watch. I found most of the information, but I couldn't figure out exactly where and how the button flex assembly is connecting to the rest of the watch.
Thank you so much for making the teardown video and pictures, it's very helpful and interesting.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If you look at these two pictures you can see the IFIXIT Teardown team had a hard time taking the watch apart as they ripped the cable connection off ;-{
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thank you! So it's a permanent connection, it can't be disconnected and then reconnected?
And what is the purpose of the small part on the left of the button flex assembly?
Also, I red at an Apple patent that the rotation of the Digital Crown is sensored with a Hall-effect sensor. Is this true? Do you know where this sensor could be located?
Thank you very much for your answers.
さんによる
I'm just an eagle eye'd person who noted the discrepancy when the teardown was first published.
I think it would be best if you got a watch to take apart for your self.
If I read between the lines here you want to take the guts out and put it into something else. Remanufacturing is always a tricky thing doing one or two might work for fun, but trying to make a business doing it I think is just not worth it.
Have you looked at the Raspberry Pi products? They may offer a better foundation than trying to modify the Apple Watch. Once you build your product you can get the parts and build your own small package system.
さんによる
My project is to create one individual object, where the Apple watch will be embedded. So I'm not planning on making a business out of this. I just need to make small modifications on the watch to incorporate into the design.
Thank you for your answer!
さんによる
コメントを追加
回答を追加する
Hajnal MacGill さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 77
