What is the maxium fan speed RPM
What is the maximum speed this achieve can go up to ? At the moment its 6500rpm and fans going
Its the i7 Macbook Air.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
How about doing a bit more digging to find out why the fan is racing here. I would install this great app: TG Pro for less than $20 you really can go wrong here.
Post a screenshot of the main screen so we can see where things are.
_
6500 RPM is the Max!
If you are running something that CPU/GPU intensive you'll need to run it on something else as your system is not designed to run that hard that long.
You''ll cook the batteries, burnout the fan bearings & the logic board will crap out.
このアンサーは役に立ちましたか?
I just want to know the maximum fan speed (RPM) .... I know *why* it's racing, because I’m using CPU/GPU intensive software,
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 2,345
