メインコンテンツにスキップ
任天堂GameCubeコントローラーDOL−003。2001年11月に発売され、任天堂 GameCube、Nintendo Wii、Wii UとNintendo Switchと互換性があります。このデバイスの修理は簡単で、一般的なツールが必要です。
46回答 すべてを表示
"A" button working like a turbo controller?
I bought a gamecube controller from china, and everything seems to work fine. But in some games that I have to press and hold the "A" button the videogame understands that I press and release and press again the button many times.
Has anyone seen anything like this? And there's someway to fix it?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
There could be a series of problems with this issue you're reporting. Since it's a knock off controller it could be:
  • Damage to the PCB during manufacturing.
  • A bad button indicator.
  • Some kind of liquid making a crossed connection.
Get a tri-wing driver, open up the device and inspect it. Clean up the area with rubbing alcohol, inspect the button and the pad it rests on and look over the cuircit board to see if there are broken traces or other signs of damage. If you're having any issues determining the problem. Take a few pictures and add them to this post to see if there is anything you may have overlooked.
Hopefully, we can get this controller working properly again. Good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Yuri Lelis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 391
