メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
Why won't iPhone 5c turn back on after turning off? Restored 3 times
The other day I switched my phone off and it wouldn't turn back on. I tried leaving to charge, hard reset, nothing worked. There was no apple logo just a completely black screen. I put it into recovery mode and connected it to iTunes where I restored everything. I then thought the phone would be fine, but once I turned it off or the battery ran out I had the exact same problem - the phone is completely dead and won't turn back on unless I go through the whole process. I really don't know what to do or what is wrong with the phone. Please can anyone help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Probably U2 Tristar charging ic at fault.
さんによる
How can I fix this? I'm desperate!
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi Sophie,
If you have used cheap cables in the past, then you have more than likely damaged a chip in the phone called the Tristar chip, this would need replacing, and for this to be repaired, you would need someone who can do microsoldering.
Try ask some repair shops in your area if they can fix this issue for you. :-)
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi thank you very much for your answer! I don't suppose you have any idea roughly how much this would cost? Thanks x
さんによる
Depends who you go to really! Try and make sure they offer 12 months warranty with their work to!
Should cost around £30 - £60 :-)
さんによる
コメントを追加
did you try a force start? While holding the Home button, press and hold the Sleep/Wake button, until the apple logo appears in about 15 seconds. If your phone refuses to charge, it is more likely a port replacement which is quick and simple, no micro-soldering, and about $60. If that is not the problem then it is the U2 IC chip, which requires micro soldering, and I don't know the success rate, if even possible.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sophie Crane さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 54
