メインコンテンツにスキップ
様々なブランドが発売してきたカメラの解体と修理ガイド
7847回答 すべてを表示
What's the Pinout to go from the camera's 6 wires to the POE Cat RJ45
MY Lorex LNB4321 camera stopped working, it had gotten water in the cable connection and the female RJ45 molded end had corroded away. I called Lorex but they wouldn't tell me the pin out to replace the end. I know the red and black go to the power plug but I need to know the which cat5 wire corresponds with the wires from the camera.
(gray, brown, purple, blue, orange, yellow)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
19 件のコメント
Need help to but my Cam has
Red, black, yellow, blue, white, green, orange, brown
さんによる
I have the same Problem here is my fix Flir 2MP model No N133ED
Orange <--------> Orange
Yellow <--------->Yellow
Brown <--------->Brown
Purple <--------->Purple
Blue <------------>Blue
Gray<------------>Gray
Run Test and is all working for me
さんによる
Thank you so much the problem resolved ,great
さんによる
I am so lost here. Can someone break this down for me as I have the same problem.
さんによる
David, what camera do you have. The pin outs are different. But if you need to kind of know what to do if you have the correct pin outs I will be glad to help.
さんによる
14件以上のコメントを表示
コメントを追加
9件の回答
ベストアンサー
I reverse engineered the plug from another working camera with a continuity tester. The connection for the Lorex LNB4321-C is:
Camera Cat 5-6
Gray<------------> Brown/white
Yellow <---------> Blue
Orange <--------> Green
Brown <---------> Orange
Purple <---------> Orange/white
Blue <------------> Green/white
Red <---> Power Plug
Black <-> Power Plug
Blue/white and Brown are not used
このアンサーは役に立ちましたか?
スコア 9
15 件のコメント:
Thank you so much. Your pin-out worked for my LNB8111-C camera. Except I doubled up the BRN+BRN/WHT-> Grey and the BLU+BLU/WHT->Yellow because POE uses pins (4+5) and (7+8). So basically I used the cables you had left over.
さんによる
Hello Alvaro, can you explain what you mean by "doubling up" on pin 5 and pin 8?
さんによる
Add a jumper wire from 4 to 5 and 7 to 8
さんによる
Thanks very much!!! I recently bought and installed the newer Lorex N841A8 4K NVR system with 8... E891AB cameras. One was damaged because I didn't properly protect the connector. It rained and shorted the female connector end of the camera. I called Lorex who promised to send an email of the color coding, I'm still waiting to get that! I searched and found your post, tried it and with fingers crossed it took just under 1:30 seconds for the camera to come back online. WORKS FINE!!! Thanks again!
さんによる
doubling up.... no answer.... he solved and all the world rest in peace.
What kind of people!
"doubled up".... the new technical language.
Only him know what doubling up means!
さんによる
10件以上のコメントを表示
コメントを追加
I had two damaged cameras but the solutions here did not work for my camera models. This is what worked for me.
PoE Camera Wires to Cat 5/6 Connector (T568B) for these Camera Models
Lorex LNB3143B
Lorex LNB3142B
FLIR N133BD
Camera –> T568B Color (Pin#) Function
Purple –> White/Orange Stripe (1) Tx +
Brown –> Orange (2) Tx –
Blue –> White/Green Stripe (3) Rx +
Yellow/Orange Stripe –> Green (6) Rx – (camera wire color may also be Orange)
Gray –> White/Brown Stripe (7) DC +
Yellow –> Brown (8) DC –
Alternate Power Connection
Gray –> Blue (4) DC +
Yellow –> White/Blue Stripe (5) DC –
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Thanks to the above post
Fix my LNB8005-c
water corrode and damage my connection, had to replace with female cat 6 jack. strip wire had 8 colour inside purple,brown,orange,green,brown,blue,red and black.
red and black not used.
gray goes into two slot 4 & 7
Yellow goes into 2 slot 5 & 8
Yellow->Orange Stripe –> Green (6) Rx – Orange
Gray –> White/Brown Stripe (7) DC + & Blue (4) DC +
Yellow –> Brown (8) DC – & White/Blue Stripe (5) DC –
さんによる
Thank you, this pin out worked for my LNB8973-C
さんによる
I have a lnb8973-c also. Didn't work for me, the camera also has a green and a white that's not mentioned
さんによる
コメントを追加
After 3 of my cameras LNB8005-C falling victim to moisture failure in the RJ 45 connections I finally tore one of the female connectors apart to repair them using ‘jelly beans’ connectors. 6 conductors in camera cable below the 12 volt plug in, yellow and grey are using 2 pins each. See photo below. Hope this helps someone else.
Color - Pin
Brown - 1
Purple -2
Orange - 3
Yellow - 4&5
Blue - 6
Grey - 7&8
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This is the pinout/wiring order that worked for my Lorex LNB8105X-C Camera:
Camera Wire (6)   ->   Cat5e Wire (8)
Brown   ->   Orange/White
Purple   ->   Orange
Orange   ->   Green/White
Yellow   ->   Blue & Blue/White
Blue   ->   Green
Grey   ->   Brown & Brown/White
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
when connecting the yellow to a rj45 do i have to bridge the blue and the blue /white and the same for the grey wire.
さんによる
No it doesnt help. I was given what looks like a reg sec camera black with "amaqua motion sensor" written on it. Its back and has no shade cover over the top front like most cameras. It has a solar cell looking protrusion from the top that has a small screw open part and it accesses a very small chamoer likeely not big enough to splice in. six wires exit the camera, the screw cover has a round and a square hole. I have motion sensors if needed and solar cells if needed, batteries too. in the very back a screw in hole with no access about 3/8" diameter. Color matching says nothing to me and im an electrician. I need to know what the wires should go to and i can work out the wires that go where once I know what it had. cant find the exact showing all info but one pic only had a solar panel on top but nothing further. "Not used" isnt accurate as they have a function i may or may not use. Without knowing my system and my system I get zip from ur description.
さんによる
I am not trying to insult you and I appreciate ur out here trying to help people with something I'm sure you have spent of time and frustration figuring out. if ur lucky and someone has the same system type and accessories with same wire colors then ur method could help them but it just isn't a way that will help most people out. Just advice sir. I'm stuck on the same thing as you and urs is working and mine isnt so thats saying something. i have a degree with electronics but ive yet to try to just work the wires back like ur buddy. im 1 1/2 hr in and a wiring diagram makes a short inspection and a few glances then i can find and add and wire it all. usually 2 searches max and i see what im seeking but not with this one. lol. Well. Thanks for ur generosity of time. Be well.
さんによる
コメントを追加
David, that is a very sweet and expensive camera. It should still be under warranty as it has a 2 year warranty. So you definitely need to contact customer support.
The problem with the pinout is that the camera is so new, I have not seen any pinouts for this yet. And because it is motorized I would imagine all the pins might be in play. Which is different then most of the others I have seen.
Our problem is rust or corrosion on the contacts. I find it hard to believe that could happen so fast to a camera that is really built for the outdoors. If it is corrosion on the cat 5 end. That can easily be replaced with another connector as the pinouts are all standard. Definitely gets tricker on the other end (camera end). One thing to try is to put vinegar in a glass and disconnect the cables and soak the connectors in the vinegar for an hour or so. then use a very small brush (childs toothbrush) on the contacts. rinse them off with clean water, let them dry…perhaps a light coating of wd40 and retry them. Mine were so severely corroded that I had to replace both ends. And then I put electrical tape over the connectors and dropped them in a plastic baggie. Hope this helps. Feel free to ask any question.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Camera is an E893ab which is POE and has the 2 spot lights on the front
Here is the pin out for it.
Camera Connector
Brown Brown & Brown/White
Blue Blue & Blue/White
Orange Orange
Orange/White Orange/White
Green Green
Green/White Green/White
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Does anyone know what the Brown|Blue|Orange|Orange/White|Green|Green/White on the camera do?
さんによる
コメントを追加
I have similar problem with my Anlapus PoE camera. It stopped working and when I checked the cable, there was no continuity from the camera terminals to corresponding RJ45 pins. I got more curious to open up a balun-like enclosure close to the RJ45 input jack where I found out it had some chips and other components some of which were faulty. I also discovered unusual cable colours from the camera to the hardware thus:
Red, Black, Purple, Blue, Green, White-blue and White-green.
Does anyone know what signals the three unusual colours carry (Red, Black and Purple)?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello everyone, I have seen a series of UTP cables for Dahua brand cameras that use the following combination:
White orange, orange White blue, blue White green, green White brown, brown.
Do you know which protocol this is? Thank you for your help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Standard cat 5e wiring. Google Cat5e and you will see that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
john mann さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 80
過去 30 日: 405
今までの合計 31,738
