メインコンテンツにスキップ
Most common size of Tesa 61395 of tape to purchase?
Being a newbe, can anyone of the I fix it Gods advise what width of Tesa tape is used the most on Apple products?
I do not want to purchase every size but maybe one or two widths most commonly used?
I see they have it back in stock so I would like to order some.
Thank you for your wisdom!
Jakester from northern Michigan
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Did you review this video? iFixit Pro Workshop: Expert Guidance From The Team At Tesa Tape
Are you working mostly on iPhones & iPads?
Tesa 61395 Tapeの画像
製品
Tesa 61395 Tape
$5.99
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Hey Dan, Yes, I did watch the Video, well almost all of it......
I think you can disregard. I believe I was confusing Tesa tape with Polyimide tape. Sorry about that. As I stated I'm a new guy.....
However, now you have me thinking (scary). Do you use Tesa tape? If so may I ask what it is used for?? And yes, I will mostly be working on Apple products.
Thanks again for your help!
Jakester
さんによる
Tesa tape is mostly used in the phones & tablets which I don't service. I mostly use Kaptan (Polyamide), Aluminum Foil, Gasket tapes.
さんによる
コメントを追加
回答を追加する
Lowell Jacobsen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 606
