Why wont headlights turn off
Headlights stayed on after shutting car off. What do I need to do?
Dori,
Check out this thread and see if it helps you figure out your problem.
Additionally, if you google "grand am headlights stay on"
You get a bunch of information on your question and as a shotgun solution you might find an answer to someone's problem that is similar to yours.
Regards,
Frank
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,651
1件のコメント
Are they on while driving, even without turning them on? Do they eventually turn off, not from a dead battery? When you shut the car off, is the headlight switch off also?
R Trent さんによる
