Why can't I open what I plugged in to the USB?
My USB port is not detecting anything. Any help?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Check for dirt or lint in the port if you do need to clean it do it with toothpick or something plastic dont use metal . If this brings no joy try a different cable . or check for a loose usb port on the laptop. If there is no damage and bad cable try reloading the drivers to the usb in the device manage. If your not sure how to load drivers get back to us and we'll help with that Hope this helps
このアンサーは役に立ちましたか?
Also to add to Jimfixer's good answer, try connecting any USB device which shows that there is power coming from the USB port e.g. a mobile phone's charging light, USB optical mouse, etc to prove that there is power on the USB port.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 87
