Hi Chris and all others who need this info. I build drones of all sort, and I also must repair them when they break. I have crossed paths with this issue and have found, as the top answer suggests, that this is due to a bad transistor/diode on the flight controller. This is a relatively easy fix for those good with smd soldering:
Locate which motor is the one spinning, look on the flight controller or “circuit board” where that particular motor plugs in and locate a three legged diode nearest that motor. Be sure to compare and take notice that each motor has the very same package (dioide) next to it, and with a magnifying glass read the markings on top of the package. This is the part you will need to replace.
If you’ve got old parts just look around and you will be sure to find one you can salvage off of an old board. With a bit of flux and a heat gun, carefully remove the old part.
Once you have the replacement part situated properly on your board, use a soldering iron to touch each leg ever so carefully for a second or two each.
Make sure that each leg has successfully been soldered in place and then use some denatured alcohol to clean your board prior to testing the board out.
If the new part is good, and you’ve done the job correctly, you will see that the motor no longer spins upon connection to the battery.
16 件のコメント
Chris, I don't know where you can get the board, but I see that Pfaff below has steered you to some resources for that.
Damian Appert さんによる
I had the same problem after the quad hit a wall. I decided to unscrew the bottom before throwing away the quad. I found a broken wire. I resoldered it and the quad work's fine.
Don Gall さんによる
If ur wire was the problem ur motor wouldn't spinat all that's not what to him , Chris you have the transistor to that motor burned out , u would have to replace it , when it burns it stay open so the electricity continues on to the motor with out an on and off switch which is the job of the transistor , I had that happen to a few of my toy drones ,
DannyDieHard さんによる
Danny how can i fix it i have the same issue
Universal Footage さんによる
Part 1 of 2
If you have tools and patience id suggest carefully open it up in a well lighted place in a shallow box lid with white paper sheet base etc.
This way you wont loose the tiny parts.
Take photos to record how it goes back together.
Safely saving those very small screws / parts etc .
Using a high quality magnifying glass and backlight eg torch shone onto the board at an angle, look at the circuit board.
You will see at least 4 FET transistors or similar ( tiny, usually 3 leg black color devices).
Each one drives the motor ie turns it on/off and lets it spin.
Look closely, you may notice one of the transistors ( ie the one driving / closest to your machine's problem motor connection wires)
is deformed shape ( blown open or bulged etc ) .
If not visibly blown then you will need an electronics guy test it and/or to remove it and test it.
If youre lucky , and confirm its the problem root cause device, buyng one and replacing it might fix for < 4USD on e-bay.
Gerard Kenny さんによる
11件以上のコメントを表示
