Error Code F H flashing
Our water recently froze and once we got it unfroze the washer started running fine then just before the rinse cycle it started flashing F then H and won't finish draning or spinning.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
When a Kenmore washer displays the F/H error, it means the washer isn’t filling with water, possibly due to defective water supply valves, siphon problems or a frozen fill line. Check your lines are open and that there isnt some sort of other blockage or damage from the frozen water lines. Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 209
