メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Won't turn back on
I took the iPhone 5s apart to clean some fluff from the rear camera but after reassembling it won't turn on. When I took it apart the first time it was stuck then suddenly opened and the home button flex cable connector and metal clip came off but it didn't look damaged. I've since replaced the home button and flex cable but it's still not turning on. Any suggestions ?
Update (01/07/2017)
Thanks
I've not got another battery but when I connect it to a PC iTunes starts and says can't connect to iPhone because it locked but nothing on the phone display
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Try swapping in a known good battery and charging port if you can get access to one. Then try plugging it into iTunes, if it turns on perfectly fine, then narrow it down to one part. If it doesn't connect to iTunes, your board is most likely bad.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You have shorted the anode filter bead on the backlight circuit. A local repairer can fix this easy. Always remove the battery 1st!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I suppose it's possible that I could have shorted some pins when re-attaching the 3 connectors on the top right while the battery was still connected, not my best move! I'm not sure if you can damage a filter cap by shorting it?
Is the backlight circuit on the logic board or the display?
さんによる
hi Melfyn.
i can say for 100% on the 5s that the anode emi filter bead is blown. this is only a small part and is a quick fix for any repair technician. on the 5s the backlight driver ic , coil and diode rarely fail even when shorted. the filter bead is just below the lcd connector socket on the logic board
さんによる
コメントを追加
Backlight ic is on the logic board, but if you are lucky and the ic isn't damage then a new screen will fix the problem, don't forget to disconnect the battery first and place the screws in the correct order ( to prevent damage the logic board ) on the metal plate that covers the 3 connectors of the screen.
Sorry for my poor English.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Would this prevent the phone from switching on or just the display working? There's no vibration when I switch the silent switch on/off.
さんによる
thats is why you dont see a image on the screen, when you take a torch and view from a angle may you can see the image.
さんによる
コメントを追加
回答を追加する
Melfyn Edwards さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 92
