Oil Light Wont go off
Even though I have changed my Engine Oil, my dashboard is still flashing 'Change oil".
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@longdicky ,Kuuku, Reset oil service light procedure. Turn the ignition on without starting the engine, press accelerator pedal to the floor three times within five seconds, If oil life light flashes(system is resetting), turn off ignition when light stops flashing. Repeat process if it does not work the first time. Check the video links below also to see the procedure. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 32
今までの合計 2,259
