メインコンテンツにスキップ
The Panasonic LUMIX DMC-LX100 is a compact digital camera with 12.8 MP resolution, 4K HD video capabilities, and Wi-Fi access. It was released in November 2014.
23回答 すべてを表示
Lens error, lens won't come out of the barrel
When starting it up the lens won't come out of the barrel and a message "lens error" shows up.
Is the lens part serviceable? Replaceable?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Thank you for the elaborate answer. I am afraid I will need to buy a new one...
さんによる
コメントを追加
1 件の回答
選択されたソリューション
A whole range of different faults can cause Lens Error, both electronic and mechanical. If it's a mechanical problem there are a few things you can try listed at https://wiki.restarters.net/Compact_came...
If none of those work, realistically, your only hope is probably to look out for another camera of the same model on ebay with a different fault - hopefully you could get one quite cheaply. Swapping the lenses shouldn't be too difficult.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Joost Lomans さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 2,378
