モデル番号A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 プロセッサ
228の回答 すべて表示
1 Beep every 5 seconds!
I change the memory, the power supply, the Logic Board and the Processor and change the hard drive just in case, but still one beep every 5 seconds!!!! What can I do? The iMac does not boot, just turn on the fan... I tried SMC reset and other keyboard fixes but the keyboard looks like does not have power. :-(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
2回答
最も参考になった回答
On the Apple site it tells that there's no RAM or it's not supported. It only supports 600 MHz PC3-12800 DDR3 SDRAM SO-DIMMs (204-pin). The RAM might also not be properly seated or the sockets are broken or the slot pattern isn't like it should be (the way the RAM is in the 4 sockets might not be in the right order) or one or more dimms are defective.
この回答は役に立ちましたか?
スコア 1
コメント:
I receive all that information and change all the memories. Also, I change the logic board and processor and the problem persist. A local Apple technician try to fix it too, but fail. Right now I have a new iMac. The one with the problem is in my office waiting for repair. :-( If there is a possibility that the problem is about software?
による
Any updates friend? My mac is beeping one time also and now i'm afraid to repair it if is possible that the error persists
による
Have you tested above things already?
による
コメントを追加
Also I got the same problem on imac 27” a1419. I would like to change power supply. Is it good idea or useless plan as like you got same experience?
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
noelfoto さん、ありがとうございました!
統計データを表示:
過去 24時間: 4
過去 7 日: 25
過去 30 日: 89
今までの合計 1,063
