How do I find replacement front casters for vacuum cart?
I'm trying to fix the front casters on a cart for a Craftsman 16 gallon wet/dry vacuum. The vacuum is model #113179930. Sears has a very helpful exploded view diagram for the product:
http://www.searspartsdirect.com/model-nu...
The casters I need are #23, Parts #: 73237. However, it seems they're no longer available, at least from Sears:
http://www.searspartsdirect.com/part-num...
Sears no-so-helpfully suggests: "The manufacturer no long makes this part, and there's no substitute part. If you choose to purchase a new product, please visit www.sears.com"
The current casters I believe have a completely missing roller bearing and therefore no longer will stay upright:
The casters slide into these attachments on the front of the vacuum cart:
Any advice to:
1) Find the exact replacement part
2) Find a suitable replacement I can install with the existing mounts
3) Come up with an entirely new wheel and mount system to pull wheels back on the front of the cart.
Thanks!
この質問は役に立ちましたか?
@luke give us some measurements. Shaft diameter and length as well as caster diameter will help us to help you:-)
oldturkey03 さんによる
Try www.CasterHQ.com for their grip ring stem casters. They were the cheapest online and shipped right away.
Jason Andrew さんによる
