Replacing the drivers window because the attachment Clips are broken o
How to remove the passenger side window and then replace it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@jesscuz , Jessica, Broken plastic window mounts. Video below will show at approx. 4.30 mark the bolts that need removed to enable window removal and install. This is the driver side window but pretty much generic to the passenger side. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 157
1件のコメント
@jesscuz not sure which attachment clips you are referring to.
Rep: 1
oldturkey03 さんによる
