メインコンテンツにスキップ
iPad mini4のWi-Fi対応バージョンの修理ガイドです。モデル番号はA1538。2015年9月9日に発表されました。iPad mini4はiPad mini3の後続モデルです。
97回答 すべてを表示
Why is home button not working now, on ipad mini 4 wifi?
The initial repair was a broken headphone jack. I tried several ways to remove the broken off jack. I ordered a replacement and used that to perform the repair.
In the teardown I mistakenly tried to separate the glass from the digitizer. That resulted in the screen malfunctioning. I ordered a replacement on my dime. I have installed that without any trouble. The home button is not responding after the repair. I was very careful removing it and do not believe it to be torn anywhere. That said there is no response from the button at this point.
Any help would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
In response to kmcrawford111:I believe the white ring you refer to is dried super glue. If I get a chance to take it apart again I will clean the old adhesive and put new in there. Thanks for the suggestion. I did not put new adhesive or super glue on before reassembling. I was very careful taking it apart and felt confident that I could reuse the adhesive that was there (apparently I was incorrect). Thanks for the response.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I had a similar issue. How did you reattach the metal bracket behind the button? I removed all of the adhesive (and the surrounding glue) from the display where the bracket attaches, and from the bracket itself, and then installed new double-sided adhesive pieces (cut to match the sections where the bracket attaches) before firmly pressing the bracket back onto the display. I did not put new glue on. So far it is working OK. Before I did all this, the operation of the button was terrible. It seems to be important that the bracket is reinstalled properly, and probably with new adhesive. There was also a little white ring with adhesive around the button itself, which I did re-use.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
jimesta さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 792
