back camera is not showing clear it's blearing
back camera is not working, it's showing blur also clicks are bluring ,can camera is damage or any software issues
It is most likely that the camera is damaged, but it could be the software to find out we can do a few tests.
1) how does this affect the picture is there a problem with focusing or is it a constant spot that is alway blurry if it is one spot that is always blurry it is probably the camera that is damaged
2) if it is a problem focusing, does this issue persist in a different camera app
3) do a factory data reset this will fix any software problem
if you conclude that it is a damaged camera here is the part: http://www.etradesupply.com/oem-samsung-...
and this video should help you with the repair: https://www.youtube.com/watch?v=WvrtIvAR...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 426
