Is there a fix for directional "wandering" on Xbox one controllers?
On all three of my XB1 controllers the arrow, reticle, or avatar will move or wander on its own even when not touching thumbsticks: IS THERE A FIX FOR THIS?? or is this how MS gets an extra $70 out of each Xbox owner every few months? ANYONE??
この質問は役に立ちましたか?
4 件のコメント
its fairly easy to fix you need to replace the entire stick mechanism inside the controller itself. I just did this job myself, follow the guide for tear down and simply de-solder all 14 points push out from the bottom insert the new mechanism and resolder the devices pins back to the board.
Marvin Warren さんによる
You don’t have to take all the points off just find out which one is bad and just take the three points off and then replace that part the green part snap on and off really easy
Phil manwarren さんによる
is there not a hard reset like the good old controllers???
Christian Homberger さんによる
How do you plan to "reset" a hardware issue?
Tom Chai さんによる
