Why I can't open my pc laptop since I insert a USB?
My pc is almost a year I didnt update the software ..and now I insert a USB my pc was ruin.. Is there probably the USB have a virus? How I can repair my pc by my own?
Check the content, also a spill or a fail in the logic board might stop the USB from taking access. Put the USB into a different PC see if it works. If yes, then a logic board problem is the case for 70%. Check the internet for fixing the logic board or the circuits for your device and contact a professional or ASUS. Also it might be a virus like you said, check with the USB producer, maybe get on their forums if they have one, and again please check with others.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 29
Does it do anything when you try to turn it on also ware did you get the flash drive?
ETHREAL1 さんによる
