メインコンテンツにスキップ
Eighth generation of the Mazda Protege.
49回答 すべてを表示
Heater only blowing out front vents, no heat to feet or defrost. Why?
Heater working but only blows out front vents. No heat to feet or defrost. Before replacing Heater Control Unit, it would only blow hot air from front vents- With this replacement it will now change from cold to hot and the air flow pressure does change from the front vents when changing the setting dial but there is still no air at all to feet and defrost. Can anyone tell me if there is a louver or valve that could be jammed and where to locate it? Or what else to try? Thanks!
Desperately Seeking Defrost :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
Thanks for information. Looking for repair guide but would appreciate any info on where to find actuator or regulator. Cheers!
さんによる
I have this problem too but with 2007 Chrysler Aspen. Had the blend door replaced and still no heat on the floor. As a matter of fact when you turn the knob to the floor vent it’s coming out of the top defrost panel b
さんによる
I have a problem my 1999 Chevy Tahoe I cant get no heat or air to blow on feet all other vents work good except for the floor vent
さんによる
2015 nissan rigue heat air only comes out of vents won't change to feet or defrost what do i replace to fix it
さんによる
コメントを追加
2件の回答
選択されたソリューション
@nothotwheels , Most likely a AC/ Heat, blend door actuator problem. Actuator could be stuck, faulty, linkage off, etc. Could not find a link for the 1998-2003 protege but will post a link to show and tell in general where and what to look for. You may also find a reasonably priced repair manual online or at the local library to borrow. Good luck.
https://www.2carpros.com/articles/replac...
このアンサーは役に立ちましたか?
スコア 10
3 件のコメント:
@lpfaff1 I know you like to ask for up votes but take a look at how that is working out for you and where your votes are actually coming from.
さんによる
@mayer , I have noticed and appreciate and I also return as you suggest, what is also nice when poster's do post back accepting the answer and leaving a comment of their gratitude, it makes it feel worth while. I am still learning things about this site and with guidance from you and others things should be good. Mayer , have also noticed you have not been answering as much as you were before, busy at the office I suppose. If I am missing something here let me know! Have a good evening.
さんによる
unplug battery for 30sec. it will reset
さんによる
コメントを追加
it must be the cable thats hooked up in to that regulator that changes the direction of air
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
How do I located the heater control
さんによる
The actuator typically on any vehicle has a flap that is controlled either manually by cable or by vacuum operated cable. It can be a labor intensive job to get to the heater box flap and then find a vacuum leak. See if you can get a shop manual on your make of car.
さんによる
コメントを追加
回答を追加する
N Wiegand さん、ありがとうございました!
統計データ:
過去 24時間: 78
過去 7 日: 472
過去 30 日: 2,480
今までの合計 172,931
