メインコンテンツにスキップ
4輪駆動車やカーゴ付き乗用車の修理マニュアル
11805回答 すべてを表示
Why dose my turn signal stop working when I apply the brakes 1994 chev
Ok so I've changed my break light switch signal light switch and every relay still when I apply my brakes my. Left turn signal stops blinking also my third brake light flashes when I turn on left turn signal
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Sounds like the third brake light is shorted to the left brake/turn light. Try removing the bulb in the third brake light and see what effect that has. If your directional lights and brake lights work normally then, I think that short is the problem. The short could occur in the switching system itself or in the wiring to the lamps. Sometimes these circuits are load sensitive, meaning if a circuit is intended to operate one lamp and it tries to do more or less, it probably will produce some odd symptoms. The switching occurs at the directional turn signal lever location and your brake switch. I hope this gives you some leads.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Give disconnected the third brake light
さんによる
コメントを追加
@afifield , Ash. Check for corroded connections in taillight wiring especially all grounds for damage/pinched and corrosion(remove ground bolts/screws/connections) clean and tighten. Also look at all the bulbs and sockets for burnt/corrosion,etc.. If you have a trailer light hook up try removing the harness as they can cause light issues when the converter in the harness is faulty which happens often. Good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Ash さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 31
今までの合計 5,724
