メインコンテンツにスキップ
モデル番号はA1347番で2.4もしくは2.66 GHz Core 2 デュオプロセッサが搭載されています。
74の回答 すべて表示
Damaged IR Sensor and Optical Drive Thermal Sensor connectors
I've done many, many repairs via iFixit's repair guides, and this is my first fatal mistake. In the process of changing the hard drive, I inadvertently pulled the logic board out too far and damaged the IR Sensor and the Optical Drive Thermal Sensor - the wires ripped right out of the connector. Note to self: buy a Logic Board Removal Tool next time.
Anyway, it wasn't clear to me from looking at the iFixit site if those parts (cables?) are available from iFixit. Is one of them part of the HD cable and the other part of the optical drive cable? If I need to sacrifice the optical drive, I'm fine with that, as I don't need it. The connectors in question are indicated in the attached picture.
I'm looking for whatever I need to buy to fix my mistake, and suggestions are appreciated - thanks!
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメント:
In my case I broke the optical-drive-thermal-sensor socket clean off the logic board. I saved the socket. Is there any way to reattach the socket, or am I stuck having to buy a new logic board?
による
コメントを追加
iPhone X用修理キット
Warranty up? No worries, we’ve got the fix.
ショップを見る
iPhone X用修理キット
ショップを見る
1回答
選択されたソリューション
Here's what you'll need:
  • Thermal Sensor Kit, ODD/Ambient, w/tape 076-1370
  • Hard Drive Flex Cable, Top, w/sensor and tape 076-1360
Update (12/17/2016)
These are Apple P/N's for the Mac Mini, not the MacBook
Here's the parts from one source:
- Thermal Sensor Kit, ODD/Ambient, w/tape 076-1370
- Hard Drive Flex Cable, Top, w/sensor and tape 076-1360
この回答は役に立ちましたか?
スコア 2
コメント:
Thanks, Dan.
Are those part numbers iFixit part numbers? Nothing is found when I search on the numbers. When I search on the part names, I get nothing for "Hard Drive Flex Cable", while "Thermal Sensor Kit" brings up 1 result for a MacBook 13" Mid 2009 part, but I still find such no part in the 68 listed for that MacBook.
による
コメントを追加
回答を追加する
mace さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 36
今までの合計 801
