Power Light Blinks On And Off (Don't Come On)
Magnavox HDTV Model 50ME313V 7 television doesn't come on. (power light blinks on and off)
if the lights are blinking in a pattern, this may indicate a trouble code. depending on the age of the set, i would suggest logging onto the mfr. website and down load a service manual. the site may a have a forum where your problem is discussed. also check out you tube for your problem; i'm sure you are not the first person to have this problem.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 8
今までの合計 539
Hi,
Is there a pattern to the blinks or are they continuous, e.g. 2 blinks - pause - 2 blinks pause or something similar etc?
jayeff さんによる
Have you checked the power supply? Normally a blinking power led suggests you have some bad capacitors.
Felix さんによる
