Can I use a nail file?
Can I use a nail file to clean the corrosion in the game card slot or do I have to use a Q-Tip with rubbing alcohol on it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Don't use a nail file to clean corrosion, you will damage the components on the board.
Use a Q-tip or toothbrush and 95%+ isopropyl (rubbing alcohol)
このアンサーは役に立ちましたか?
I have 70% isopropyl, is that ok? Also, I am cleaning the slot where you put the games in.
It's also 30% water so make sure it's dried out before testing.
ok, how do i dry it out?
You leave it to evaporate. Personally I use 99% isopropyl to bath liquid damaged boards after an ultrasonic clean. This helps quicken the drying process since it evaporates quicker than my ultrasonic cleaning solution. Usually check them a day after this to completely dry
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 79
3 件のコメント
What exactly are you cleaning?
TronicsFix さんによる
The game card slot.
kdcao1 さんによる
Never use a nail file, you'll damage the components even more.
Aaron Sasser さんによる
