Kenmore model 21252110 auto load sensing
Won't start a cycle and the lid lock light is no flashing for an error
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@mountian first thing you want to do is to unplug your machine then plug it back in after a short while (I'd give it 10-15min) This will act like a reset. After that make sure that your power outlet works. If it dos not check your circuit breakers or fuses. If that checks out okay it is possible that you have a control board issue, a failed shift actuator, or a failed power door lock. You can check the door lock for continuity with a multimeter. If that is okay, then you want to take a look at the control board for any obvious damaged components. run the diagnostics and see if it gives you an error code. Let us know what you get:
here is the sequence you'll need to go through to display the error code.
1. Be sure the washer is in standby mode (plugged in with all indicators off). (press and hold the start/cancel button for 3 seconds to turn everything off)
2. Perform the following sequence of movement using the cycle selector knob. NOTE: AFTER RESET, sequence “a” through “e” must be completed within 6 seconds.
RESET - Rotate cycle selector knob counterclockwise to clear sequence.
a. Rotate cycle selector knob clockwise one click and wait 1⁄2 second.
b. Rotate cycle selector knob clockwise one click and wait 1⁄2 second.
c. Rotate cycle selector knob clockwise one click and wait 1⁄2 second.
d. Rotate cycle selector knob counter-clockwise one click and wait 1⁄2 second.
e. Rotate cycle selector knob clockwise one click and wait 1⁄2 second.
You are now in diagnostics. Turn the knob until just the "DONE" LED is illuminated. Push START.
Turn the dial one click to see the error code that is displayed by the LED's along the progress line. Let us know which ,and if, lights appear and let us know.
このアンサーは役に立ちましたか?
Help.. My washer is acting up. I did the above steps and got sensing, rinse complete and did it again and got sensing, rinse, spin, complete.
I did this and the sensing and wash lights flash on together then the complete light flashes and it goes back and forth do you know what the problem is for me?....washer starts to fill them stops...empties water then just sits with the wash light on and nothing else
@ mihal Uknow ,
What is the model number of your washer?
@mountian . Brent, Try reset, unplug let sit 5 min. and plug in and try. If under warranty, contact the manufacturer and use you warranty. There could be a few reasons for the washer not starting, Check for power at the receptacle, check the power cord for damage, door lock could be faulty or the main board could be faulty,etc..
If not comfortable trying to diagnose or repair the washer have a good repair tech. have a look and diagnose and estimate repair. Links below may aid in diagnosing washers issue, 1st link tells about error codes and how to retrieve them for diagnosing and 2 and 3 links are trouble shooting.
http://www.searspartsdirect.com/washer-r...
このアンサーは役に立ちましたか?
These washers with the electronic board in my honest opinion is garbage.
I agree with melvinmoss87
I unplugged it, plugged it back in, rotated cycle know a few times and we're good🤞
過去 24時間: 1
過去 7 日: 12
過去 30 日: 50
今までの合計 52,482
3 件のコメント
Completed sequence.
Now have 5 flashing green lights.
Sensing, wash, rinse, spin, complete
Note -
Tech was just here and replaced pump. Still not working correctly
Cris Wyse さんによる
Ours just has the Sensing LED illuminated.
milpridemabry さんによる
I have a Kenmore and all it does is the sensing light flashes??
Michelle Kearns さんによる
