メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
Black color ist not printing correct
Hi there,
My printer does not print straight black lines anymore. All other colors are straight printed.
If I print the quality report the black Box looks horrible. No straight lines, not all of the box is printed black.
Do you have any suggestions, what I cold do?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
I have got an answer from the hp Support how to get to the secret support menu.
There I should make a semi reset of the printer. Unfortunately without any success.
さんによる
コメントを追加
全てのタブを開く
Mac用RAMアップグレードキット
キット商品を見る
どれだけタブを開いても
十分に足りるRAM容量
キット商品を見る
2件の回答
選択されたソリューション
Hi @gotti123456 ,
Way out thought.
Check if your printer settings are set up for bi-directional printing. If so disable it and see if it helps.
この回答は役に立ちましたか?
スコア 1
コメント:
How could I check this?
さんによる
Hi, Apologies, I cannot find if your printer supports bi-directional printing. (That means that it prints in both directions i.e. when travelling from left to right and right to left.This is done to speed up the printing process.)
If it is available it should be somewhere in the printer preferences area.
さんによる
コメントを追加
最も参考になった回答
Have you tried aligning the printer?
Here are the instructions according to the HP user manual:
To align printer from the printer display:
1. From the Home screen, touch the Settings icon, and then touch Tools.
2. On the Tools menu, touch the down arrow to scroll through the options, and then touch Align Printer.
3. Follow the instruction on the screen.
To align printer from the printer software:
On Windows:
a. From the Start menu on your computer, click All Programs, click HP.
b. Click the HP Photosmart 5520 series folder, click HP Photosmart 5520 series.
c. Under Print, double-click Maintain Your Printer.
d. Under the Device Services tab, double-click Align Printheads.
On Mac:
a. Open HP Utility
b. click Align and then click Align again.
この回答は役に立ちましたか?
スコア 2
コメント:
I already tried all The maintenance programs several times without any success. Lines are still not straight and the box is not correct filled with the Black color.
さんによる
Hi,
Just verifying that you have done the following.
1. Checked the Black cartridge ink level is sufficient,
2. Checked the Black cartridge vent area is not clogged.
3. Done a printhead clean.
Here is a link that shows you how.
http://support.hp.com/au-en/document/c03...
さんによる
Yes I also tried this several Times without any Access.
さんによる
Even the HP support has no idea, was the Problem is :(
さんによる
コメントを追加
回答を追加する
Michael さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 363
