メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Camera not working after screen replacement
Just after replacing the screen on my iPhone 6 I noticed how both the flash and video camera work perfectly, even the panoramic view has no problem but the camera does not work. The camera app doesn't show the screen because its all blurry. What did I do wrong and how can I fix it?.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
You may have accidentally disconnected the back camera while replacing your screen. A more common issue is, your front camera flex could've been damaged in the repair process. If the front camera goes out, it could cause issues with the back camera.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
How could I fix this issue?, im not really sure about that because I can still record but no pictures.
さんによる
i'm also going through a similar issue, my iphone seems to be seriously shoerted or something, It's draining up the battery and for some reason both the cameras and flash aren't working.
さんによる
コメントを追加
回答を追加する
Marcelo Marquez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,447
