Broken Internal Display connector
I have an iMac 27" that someone has damaged the display connector and snapped some pins from the board while attempting to replace the hard drive. Where can I obtain a replacement connector?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It needs to be soldered back together. I've done the same thing and I'm just debating selling my entire computer.
このアンサーは役に立ちましたか?
I had the same problem, only i admid i broke it myself;)
I ordered a LCD internal connector for a 27" on ebay:
http://www.ebay.nl/itm/APPLE-imac-27-inc...
Problem is to find a guy or service who can solder it on the logic board.
It should be a piece of cake for a person with some smt soldering skills, unless you can do it your self.
このアンサーは役に立ちましたか?
If you are in the US, my contact info is in my profile.
wow, thanks Mil! Looking for a solution to the exact same problem for months, I had the other problem: I found a guy who was ready to do it, but not without all the pins :) Thanks to your link, problem is gonna be solved!
This site is awesome!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,956
1件のコメント
This does not contain enough information to give you an answer. "snapped some pins from the board"? Is the is the display connector or the hard drive connector? Please take some photos so that we have a clue as to what your problems are.
mayer さんによる
