メインコンテンツにスキップ
Long time of non use
I have a Pioneer PL-44F turntable that I haven't used for 20 years or more. It comes out of its base very slowly but sticks along the way. No other features or buttons seems to work. It seems that it the problem is not being used so perhaps moving them manually to loosen things up will do the trick? Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
arch if it moves out slow and sticky it is possible that the gear or the shaft are gummed up. Take a look at the image for the location of part 3 and part 6. See if you can clean those with some isopropyl alcohol and free them up.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Old Turkey,
If I was to tear this unit down to that degree, I'd never be able to put it together again. It seems that the base is moving in & out easier, after manually helping it numerous times. However, the arm & platter do not move. Anything else you can suggest?
さんによる
コメントを追加
回答を追加する
arch さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 221
