How do I unlock my tablet, can't remember the pin I used
i can't unlock my tablet or reset it. it won't let me leave the lock screen
On the RCA tablets if you cant remember your password and have to do a hard reset on it you power it off first then when you go to turn it back on hold the power button and volume up button at the same time. When the picture of the dogs come on the screen hold the power and volume up button for 2 seconds and release. After the screen loads you should get the android on the screen and it should say no command at this point hold the volume up button for 5 seconds then a menu will come up allowing you to wipe and reset the tablet. Hope this helps
このアンサーは役に立ちましたか?
What if it don't work
No Android setting lock battery disconnect after 3 hrs did nothi b g still locked rca code 0530 does nothing any help would be appreciated I'm just gonna take the 10lb sleg to it trying for days to unlock it .,
このアンサーは役に立ちましたか?
I have the exact same problem
J’ai oublié mon mot de passe pour débarrer ma tablette …….que faire…
RCA 8 Appollo
J’aimerais avoir une réponse en français svp
Johanne Vallée
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 9,022
