メインコンテンツにスキップ
Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
118回答 すべてを表示
Green light of death help
Mitsubishi tv dlp wd60c9- tv stuck on welcome screen green light blinking green fast I already replaced two 820uf capacitors still doing the same thing. The weird thing is. Is that the tv code is showing 33. Air filter cover is open. Makes no semse please help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
@joshstoney it's a beast to figure out. Most common issue with that are the caps, and I wonder why you only replaced those two? Most of these sets require a whole bunch of caps to be replaced.
さんによる
コメントを追加
1 件の回答
rsx needs reballing or your rsx chip is dead
The gpu is struggling and is on its way out, hairline splits in the solder balls etc.
Plus the solder balls used on the ps3 gpu is tin and sh!t quality, high quality lead solder balls last alot longer
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josh stone さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 116
